Старый 15.01.2014, 15:11   #1
Pawan's Ax blog: Compare objects among 2 or more layers in Ax2012
Источник: http://pawansaxblog.blogspot.com/201...re-layers.html
Sometime we might like to find objects existing in two or more layers i.e. layer 1 AND layer 2. Out of box we have a feature of creating a project for objects present in specific layers i.e. layer 1 OR layer 2.
So with below job you can build on this standard feature thereby finding common objects i.e. objects present in all(AND condition) the specified layers only.
Note : If you try to iterate whole AOT thru code it becomes performance intensive hence not advisable to do it. So always create one project and then further work on it.
static voidlistAllObjectosFromProject(Args _args)
ProjName projName = "CompilerOutput"; // Specify your project area name here
ProjectListNode list = infolog.projectRootNode().AOTfindChild("Shared");
TreeNodeIterator ir = list.AOTiterator();
ProjectNode pnProj,projectNode;
ProjectNode pn = list.AOTfindChild(projName);
SetEnumerator setEnumerator;
Set set;
container layers;
#define.ProjectName("Compileroutput_Sub") // Sub project Name. You may like to change it as per you like.
voidsearchAllObj(projectNode rootNode)
#TreeNodeSysNodeType
TreeNode childNode;
TreeNodeIterator rootNodeIterator;
projectNode = SysTreeNode::getPrivateProject().AOTfindChild(#ProjectName);
if(!projectNode)
projectNode = SysTreeNode::createProject(#ProjectName,ProjectSharedPrivate::ProjPrivate);
if(rootNode)
rootNodeIterator = rootNode.AOTiterator();
childNode = rootNodeIterator.next();
while (childnode)
if (childNode.treeNodeType().id() == #NT_PROJECT_GROUP)
searchAllObj(childNode);
else
//info(strfmt("Group :%1 - Object: %2", rootNode.AOTname(), childNode.AOTname()));
set = childNode.AOTLayers(false);
setEnumerator = set.getEnumerator();
layers = conNull();
while(setEnumerator.moveNext())
layers = layers +enum2Symbol(enumName2Id('UtilEntryLevel'),setEnumerator.current());
if(confind(layers,'syp') && confind(layers,'usr')) // Put your layers here in which you want to check objects
info(strFmt('Name: %1, Layers: %2', childNode.AOTname(),con2Str(layers) ));
projectNode.addNode(childNode);
projectNode.AOTsave();
if (pn)
info(strFmt("Project %1:", projName));
pnProj = pn.loadForInspection();
searchAllObj(pnProj);
pnproj.treeNodeRelease();
else
info("Projet objects");
Часовой пояс GMT +3, время: 17:25.
