Старый 09.02.2014, 19:03   #1
Remember how many times you were typing code on a line and hit the invisible wall of 130 chars?
A lot of times, I suppose. At least I have.
Well, with NAV2013 you can get up to 240 chars!
Definitely useful if you copy a function with all its parameters in it to your code where you want to use that function.
But for the rest I would advice anyway to limit yourself to 130 chars.
Why? Because not everyone has a very-wide screen for starters and also because it is just too wide to have a good overview of the code.
And in case you write some code that you want to downgrade to older versions, you better limit yourself to those 130 chars!
Читать дальше
Часовой пояс GMT +3, время: 09:40.
