Старый 11.02.2014, 16:11   #1
25,644 / 848 (80) +++++++
atinkerersnotebook: Publish Queries As OData Document Sources For Users To Query In Excel
Источник: http://atinkerersnotebook.com/2014/0...uery-in-excel/
Originally posted on Dynamics AX Tip Of The Day:
If you want to publish out data to the users so that they can create their own reports, or run their own analysis, there is in a simple and secure way built into Dynamics AX. You can register your queries as Document Data Sources and then they automatically become available through the OData service within Dynamics AX. Additionally, all of the default security that you put in place around the data will be respected by the service because you are using Dynamics AX to create the query.
No more ODBC connections, or even worse? unsecured Access databases.
How To Do It…
View original
atinkerersnotebook: Using Export To Excel in Dynamics AX to Create Reporting Data Sources Blog bot DAX Blogs 1 12.10.2013 01:13
dynamicscare: Using Power BI to Analyze Your Dynamics AX Data Blog bot DAX Blogs 1 06.10.2013 18:11
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
Часовой пояс GMT +3, время: 22:39.
