Старый 17.03.2014, 18:11   #1
Axilicious:The given value of type String from the data source cannot be converted to type nvarchar of the specified target column.
Источник: http://www.ksaelen.be/wordpresses/dy...target-column/
Today I experienced this problem while importing models from the build machine into one of the developer machines:
A quick search on the internet took me to this blog post that explains the importance of initializing / updating your model store after installing CU’s. To initialize/update your model store you simply have to run the AxUtil with the schema command. (Alternative for powershell is Initialize-AXModelStore)
For a full list of AXUtil and PowerShell commands, please refer to MSDN.
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
Axilicious:Data Migration Framework Hands-on Blog bot DAX Blogs 0 29.07.2012 13:11
ax-erp: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] Blog bot DAX Blogs 0 18.07.2012 12:11
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 08:14.
