Старый 03.09.2014, 15:10   #1
25,644 / 848 (80) +++++++
Unfortunately, it is not possible to select multiple filter values for an option field on a request page of a report in the Web Client. This is however possible in the Windows Client. In the GUI of the Web Client it is possible to select a range as a filter though there is no underlying coding that supports this. Documentation around limitations of Web Client can be found here.
The Web Client was originally designed for an occasional use as opposed to intensive use for which we have the Windows Client. Partner and Customer feedback has clearly indicated that the strengths of the Web Client (e.g., easy to deploy, runs in major browsers) have pushed adoption well beyond its’ intended use. In feature releases we will therefore address the functionality of the Web Client further.
These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use.
Marco Mels
Microsoft Dynamics NAV
Источник: http://feedproxy.google.com/~r/Micro...ws-client.aspx
Часовой пояс GMT +3, время: 06:01.
