Старый 19.04.2015, 05:57   #1
Control Add-ins written in C# are not cross-version compatible. You cannot use an assembly compiled for 2013 R2 with 2015 (or the opposite way around, or any other version combination for that matter) without recompiling it with correct extensibility framework assembly reference.
Control Add-ins written in JavaScript don’t have to be recompiled, are mostly interchangeable, and are (so far) guaranteed to be forward compatible. You can always use a version built for 2013 R2 in 2015. You can use a version built for 2015 in 2013 R2, but the opposite way around is only true if you don’t use any of the new JavaScript extensibility features not supported in earlier versions.
Read this post at its original location at http://vjeko.com/blog/control-add-in...-compatibility, or visit the original blog at http://vjeko.com. 5e33c5f6cb90c441bd1f23d5b9eeca34The post Control Add-ins and Version Compatibility appeared first on Vjeko.com.
</img> </img>
Читать дальше
Часовой пояс GMT +3, время: 19:09.
