Старый 29.04.2015, 19:11   #1
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Online patterns & principles for solution builders
Источник: http://blogs.msdn.com/b/crm/archive/...-builders.aspx
Applies to: CRM Online
In the world of Microsoft Dynamics CRM, the shift to the cloud is well underway. Microsoft Dynamics CRM Online is growing by leaps and bounds, including sales to massive customers with huge user counts. If you’re a partner in the Microsoft Dynamics CRM channel, it’s important that you understand what this means for the solutions you build for customers who want Microsoft Dynamics CRM Online.
You may believe that the difference between building a solution for an on-premises and an online deployment consists of a few technical details, like the requirement to use FetchXML for reports in online deployments, or the requirement to sandbox plugins. But in reality, the differences are much deeper than that. To truly build a high-quality solution for Microsoft Dynamics CRM Online, you need to do more than simply build the on-premises way and then check a few extra boxes.
The Microsoft Dynamics CRM Online patterns & principles for solution builders whitepaper describes the new mindset required to successfully design solutions for online deployment. Check it out at the following location!
Download: Patterns and Principles for CRM Online Solution Builders.pdf
Your feedback is always welcome.
Thank you!
Andy Schultz | LinkedIn | @andrewbschultz
Marc Schweigert | Blog | LinkedIn | @devkeydet
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
Microsoft Dynamics CRM Team Blog: Fast, Efficient Growth for Project Management Solution - Case Studies Blog bot Dynamics CRM: Blogs 0 01.02.2012 03:18
Microsoft Dynamics CRM Team Blog: CRM Online: Reporting Options Blog bot Dynamics CRM: Blogs 0 18.06.2009 06:14
Часовой пояс GMT +3, время: 17:50.
