Старый 29.01.2008, 11:27   #1
The language module file helps you to save the existing text messages and captions, and propagate them to the Outlook Integration Update objects. How to apply the language module file to the C/AL objects provided with the Outlook Integration Update: Before you import the objects you received with the Outlook Synchronization Update package, open your localized version of the database. Select the objects which are going to be replaced by the Outlook Synchronization Update objects (18 objects should...(read more)
Подробнее... http://dynamicsuser.net/blogs/navsustatine...cs-nav-5-0.aspx
Часовой пояс GMT +3, время: 04:45.
