Старый 02.06.2008, 14:56   #1
New page
The hosts file and the services file are used (in place of [[DHCP]]) to redirect connections to a specific TCP/IP address on the network.
The files are located in
C:WINDOWSsystem32driversetc
they do not have extensions.
==Use in Dynamics NAV==
==hosts==
The default hosts file in windows will look something like:
# Copyright © 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
==services==
The default services file in windows will look something like:
# This file contains port numbers for well-known services defined by IANA
# Format:
# <service name> <port number>/<protocol> [aliases...] [#<comment>]
echo 7/tcp
echo 7/udp
discard 9/tcp sink null
discard 9/udp sink null
systat 11/tcp users #Active users
daytime 13/tcp
daytime 13/udp
qotd 17/tcp quote #Quote of the day
qotd 17/udp quote #Quote of the day
chargen 19/tcp ttytst source #Character generator
chargen 19/udp ttytst source #Character generator
ftp-data 20/tcp #FTP, data
ftp 21/tcp #FTP. control
telnet 23/tcp
smtp 25/tcp mail #Simple Mail Transfer Protocol
time 37/tcp timserver
time 37/udp timserver
rlp 39/udp resource #Resource Location Protocol
nameserver 42/tcp name #Host Name Server
nameserver 42/udp name #Host Name Server
nicname 43/tcp whois
domain 53/tcp #Domain Name Server
domain 53/udp #Domain Name Server
bootps 67/udp dhcps #Bootstrap Protocol Server
bootpc 68/udp dhcpc #Bootstrap Protocol Client
tftp 69/udp #Trivial File Transfer
gopher 70/tcp
finger 79/tcp
http 80/tcp www www-http #World Wide Web
kerberos 88/tcp krb5 kerberos-sec #Kerberos
kerberos 88/udp krb5 kerberos-sec #Kerberos
hostname 101/tcp hostnames #NIC Host Name Server
iso-tsap 102/tcp #ISO-TSAP Class 0
rtelnet 107/tcp #Remote Telnet Service
pop2 109/tcp postoffice #Post Office Protocol - Version 2
pop3 110/tcp #Post Office Protocol - Version 3
sunrpc 111/tcp rpcbind portmap #SUN Remote Procedure Call
sunrpc 111/udp rpcbind portmap #SUN Remote Procedure Call
auth 113/tcp ident tap #Identification Protocol
uucp-path 117/tcp
nntp 119/tcp usenet #Network News Transfer Protocol
ntp 123/udp #Network Time Protocol
epmap 135/tcp loc-srv #DCE endpoint resolution
epmap 135/udp loc-srv #DCE endpoint resolution
netbios-ns 137/tcp nbname #NETBIOS Name Service
netbios-ns 137/udp nbname #NETBIOS Name Service
netbios-dgm 138/udp nbdatagram #NETBIOS Datagram Service
netbios-ssn 139/tcp nbsession #NETBIOS Session Service
imap 143/tcp imap4 #Internet Message Access Protocol
pcmail-srv 158/tcp #PCMail Server
snmp 161/udp #SNMP
snmptrap 162/udp snmp-trap #SNMP trap
print-srv 170/tcp #Network PostScript
bgp 179/tcp #Border Gateway Protocol
irc 194/tcp #Internet Relay Chat Protocol
ipx 213/udp #IPX over IP
ldap 389/tcp #Lightweight Directory Access Protocol
https 443/tcp MCom
https 443/udp MCom
microsoft-ds 445/tcp
microsoft-ds 445/udp
kpasswd 464/tcp # Kerberos (v5)
kpasswd 464/udp # Kerberos (v5)
isakmp 500/udp ike #Internet Key Exchange
exec 512/tcp #Remote Process Execution
biff 512/udp comsat
login 513/tcp #Remote Login
who 513/udp whod
cmd 514/tcp shell
syslog 514/udp
printer 515/tcp spooler
talk 517/udp
ntalk 518/udp
efs 520/tcp #Extended File Name Server
router 520/udp route routed
timed 525/udp timeserver
tempo 526/tcp newdate
courier 530/tcp rpc
conference 531/tcp chat
netnews 532/tcp readnews
netwall 533/udp #For emergency broadcasts
uucp 540/tcp uucpd
klogin 543/tcp #Kerberos login
kshell 544/tcp krcmd #Kerberos remote shell
new-rwho 550/udp new-who
remotefs 556/tcp rfs rfs_server
rmonitor 560/udp rmonitord
monitor 561/udp
ldaps 636/tcp sldap #LDAP over TLS/SSL
doom 666/tcp #Doom Id Software
doom 666/udp #Doom Id Software
kerberos-adm 749/tcp #Kerberos administration
kerberos-adm 749/udp #Kerberos administration
kerberos-iv 750/udp #Kerberos version IV
kpop 1109/tcp #Kerberos POP
phone 1167/udp #Conference calling
ms-sql-s 1433/tcp #Microsoft-SQL-Server
ms-sql-s 1433/udp #Microsoft-SQL-Server
ms-sql-m 1434/tcp #Microsoft-SQL-Monitor
ms-sql-m 1434/udp #Microsoft-SQL-Monitor
wins 1512/tcp #Microsoft Windows Internet Name Service
wins 1512/udp #Microsoft Windows Internet Name Service
ingreslock 1524/tcp ingres
l2tp 1701/udp #Layer Two Tunneling Protocol
pptp 1723/tcp #Point-to-point tunnelling protocol
radius 1812/udp #RADIUS authentication protocol
radacct 1813/udp #RADIUS accounting protocol
nfsd 2049/udp nfs #NFS server
knetd 2053/tcp #Kerberos de-multiplexor
man 9535/tcp #Remote Man Server
==See also==
*[[C/SIDE server]]
*[[DHCP]]
*[[Network]]
*[[Hosts and services]]
[[Category:Server]]
Источник http://wiki.dynamicsbook.com/index.php?tit...ts_and_services
Часовой пояс GMT +3, время: 09:18.
