Старый 31.08.2012, 13:59   #1
Sorry hier der Nachtrag zum LiveMeeting Demo dies ist die entsprechende Meldung meiner Demoumgebung
Type: Text
A text string that contains the call stack from where the error occurred.
The format of the string is:
<codeunit name>(Codeunit <number>).<function name> line <line number>[<calling codeunit name>(Codeunit <number>).<calling function name> line <line number>...]
The string cannot exceed the maximum string length that is specified in Microsoft Dynamics NAV, which is 1,024 characters.
If no error has occurred, then the function returns an empty string.
For some errors, such as divide by zero errors and overflow errors, GETLASTERRORCALLSTACK does not return every call in the stack. To get the complete call stack for these types of errors, use the debugger and specify that you want to break on errors. On the Debugger page, in the Call Stack FactBox, you can view all the function calls that led to the error. For more information, see How to: Break on Errors.
Далее
Часовой пояс GMT +3, время: 10:42.
