Старый 09.02.2014, 18:51   #1
Before NAV2013, the names of variables (and functions) were limited to 30 chars. In NAV2013, you can go beyond that length.
I did some tests to see if NAV only considers the first 30 chars or also considers the chars after that length. NAV2013 considers also chars beyond the first 30!
I didn’t check out how long the variables can be because I think that 30 chars is long enough.
And in case you write some code that you want to downgrade to older versions, you better limit yourself to those 30 chars!
Читать дальше
Часовой пояс GMT +3, время: 08:58.
