Старый 23.08.2016, 19:12   #1
25,644 / 848 (80) +++++++
stoneridgesoftware: DIEF Issue – “DataMigrationImportExportFramework” is Missing from Event Viewer
Источник: https://stoneridgesoftware.com/dief-...-event-viewer/
A client recently ran into this issue. On one machine running the DIXF job – the user only sees the SQLISPackage110 (source) error in the application event viewer. The client was missing the detail of why the import failed. The error message from source “DataMigrationImportExportFramework” is missing.
On another machine – the client sees both SQLISPackage110 and DataMigrationImportExportFramework source. The message in the source “DataMigrationImportExportFramework” tells you exactly what caused the SSIS import process to fail.
If this happens to you, here’s the Solution:
Change the service account for SSIS service on the server with this problem to the AOS svc.
Next, restart the Microsoft Dynamics AX data Import/Export Framework Service on your server.
stoneridgesoftware: Dynamics AX DIEF error: Package Execution Failed Please Check Event Log in DMF Service Box Blog bot DAX Blogs 0 26.05.2016 18:11
Navigate Into Success: Trick: Subscribing to any Control Add-in event through pure C/AL Blog bot Dynamics CRM: Blogs 0 04.08.2014 11:00
Rahul Sharma: Write into the System Event Viewer from Dynamics AX Blog bot DAX Blogs 0 02.06.2011 22:12
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 00:33.
