Старый 03.10.2016, 23:12   #1
dynamicsaxhints: Dynamics AX Trace Parser vs SQL Server Profiler
Источник: http://dynamicsaxhints.blogspot.com/...ql-server.html
While I was working on the previous post, I noticed a strange difference between data presented in Microsoft Dynamics AX Trace Parser and SQL Server Profiler. Let's run a couple of tests.
Problem description
Trace the following select statements in Tracing Cockpit and SQL Server Profiler and compare the results:
select AccountNum from custTable;
select firstOnly AccountNum from custTable;Solution
Setup Tracing Cockpit to collect detailed database data:
Setup SQL Server Profiler to trace RPC:Starting and RPC:Completed events:
Let's run the first select statement. The results in Trace Parser are:
20 rows were fetched. The results in SQL Server Profiler are different - 10 rows were fetched into buffer:
What is correct and what is wrong? To be honest, I don't know for sure. Maybe the tools collect different data.
Let's run the second select statement with firstOnly keyword. I expect 1 row to be fetched. The results in Trace Parser are:
0 rows were fetched. It looks very strange. Definitely 1 record was fetched into a table buffer in the job. The results in SQL Server Profiler look better - 1 row was fetched into buffer:
Conclusion
I personally trust more SQL Server Profiler because of the much longer product history. Once again it can be that the tools present different data, but starting from now I will be more cautious about the data in Trace Parser.
Please share your thoughts and expereience on this topic.
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
axinthefield: SQL Server Trace Flags for Dynamics AX Blog bot DAX Blogs 0 23.11.2010 21:11
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
Часовой пояс GMT +3, время: 20:59.
