dynamicsaxhints: Simply about applyTimeZoneOffset and removeTimeZoneOffset methods of DateTimeUtil
Источник: http://dynamicsaxhints.blogspot.com/...ffset-and.html
============== In this post I want to describe simple rules of working with an unbound UtcDateTimeEdit control in a form: 1) from the database to the user -> applyTimeZoneOffset 2) from the user to the database -> removeTimeZoneOffset Continue reading for the details. Problem description Define how to set and store value of an unbound UtcDateTimeEdit control in a form. Hints Play with bound and unbound UtcDateTimeEdit controls in a form. Solution Let's create a form with 2 UtcDateTimeEdit controls: - BoundUtcDateTimeEdit is bound to EcoResDateTimeValue.DateTimeValue table field - UnboundUtcDateTimeEdit is unbound and is based on AttributeValueDateTime EDT. The user time zone is set to GMT+02:00: Case 1. Set a value to Unbound control Assume that Unbound control value is updated in modified method of Bound control like this: UnboundUtcDateTimeEdit.dateTimeValue(EcoResDateTimeValue.DateTimeValue); When today is set into Bound control, Unbound control has 2 hours difference: Why? Because the user time zone is GMT+2 and table field value is saved in UTC time zone, so EcoResDateTimeValue.DateTimeValue field has "2/3/2017 10:00:00 pm". The same value is presented in Unbound control. The user time zone must be applied to UTC field value to display correct value in Unbound control: UnboundUtcDateTimeEdit.dateTimeValue( DateTimeUtil::applyTimeZoneOffset(EcoResDateTimeValue.DateTimeValue, DateTimeUtil::getUserPreferredTimeZone())); Case 2. Store a value from Unbound control Assume that utcDateTime table field is updated in modified method of Unbound control like this: EcoResDateTimeValue.DateTimeValue = UnboundUtcDateTimeEdit.dateTimeValue(); When today is set into Unbound control, Bound control has again 2 hours difference: Why? The value from Unbound control "2/4/2017 12:00:00 am" is treated as UTC time zone value in EcoResDateTimeValue.DateTimeValuefield. The user time zone is applied by kernel to UTC time zone field value, so Bound control has "2/4/2017 02:00:00 am". The user time zone must be removed from control value to get UTC time zone value, which can be set to table field: EcoResDateTimeValue.DateTimeValue = DateTimeUtil::removeTimeZoneOffset(UnboundUtcDateTimeEdit.dateTimeValue(), DateTimeUtil::getUserPreferredTimeZone()); Conclusions DateTime value is stored in database in UTC. The user time zone is usually different from UTC. When a value from the database must be presented in unbound control, the user time zone offset must be applied to the value. Use DateTimeUtil::applyTimeZoneOffset() method. When a value entered by the user into unbound control must be stored in database, the user time zone offset must be removed to get UTC value. Use DateTimeUtil::removeTimeZoneOffset() method. Bound control values are handled automatically by kernel. Источник: http://dynamicsaxhints.blogspot.com/...ffset-and.html
