Старый 10.02.2017, 12:11   #1
25,644 / 848 (80) +++++++
organicax: RFQ Scoring method
Источник: https://organicax.com/2017/02/09/rfq-scoring-method/
When working with suppliers sometimes you might want to value a relationship over price if the quality or the delivery performance is good. When setting up an RFQ you might want to setup a evaluation criteria that can allow you to capture some data beyond just the price. You can setup your own criteria with the scoring method. Then you can use this to update the bid entries with your internal data.
Here is a quick overview
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: Changing a planned purchase to a RFQ Blog bot DAX Blogs 0 08.02.2017 07:18
organicax: Completing the RFQ for a requisition Blog bot DAX Blogs 0 04.02.2017 10:16
organicax: RFQ default payment terms Blog bot DAX Blogs 0 04.02.2017 03:29
organicax: RFQ Case number vs request for quotation number Blog bot DAX Blogs 0 04.02.2017 03:29
Navigate Into Success: Try..Catch for .NET Interoperability Blog bot Dynamics CRM: Blogs 0 29.10.2014 09:00
Часовой пояс GMT +3, время: 10:04.
