Старый 02.03.2017, 20:11   #1
stephenmann: Can't install CDX Async server / Realtime on Windows 10 or Server 2016?
Источник: https://www.stephenmann.net/single-p...or-Server-2016
Exception             : System.MissingMemberException: Error while invoking GetType. Could not find member.
At "AddOrRemoveUserToNTGroup" in Common-Configuration.ps1: line 692
When installing AX Async service and Realtime service on Windows 10 machines the installer will fail.  When trying to install through powershell then can the the below error:
There is a couple of try/catch statements that can be added to the Common-Configuration.ps1 file to get past these errors, after this the script will continue past the error and complete the setup.
stephenmann: Dynamics AX Retail CDX (a good example of how not to integrate applications) Blog bot DAX Blogs 0 02.03.2017 20:11
german_nav_developer: Microsoft Dynamics NAV und Windows Server 2016 Blog bot NAV: Blogs 0 12.01.2017 17:11
msdn.microsoft.com/nav: Dynamics NAV and Windows Server 2016 Blog bot NAV: Blogs 0 07.01.2017 00:11
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
Channel9: AX for Retail R3 Commerce Data Exchange Async: Install Async Server (episode 1 of 4) Blog bot DAX Blogs 1 29.10.2014 10:13
Часовой пояс GMT +3, время: 16:31.
