Старый 04.04.2017, 22:11   #1
dynaxtips: Make a suggestion and get heard!
Источник: https://dyntips.com/2017/04/04/make-...and-get-heard/
If you have a suggestion for improvement or changes for Dynamics you can go to the new Ideas page and get to know the solution better. You can also go here to browse suggestions and vote them up to get the improvements that are important to YOU up on the agenda. This is a preliminary  work list that actually makes it to the product. So go get your voice heard and make the application move in your direction.
Filed under: AX7
kurthatlevik: AX suggestion: XML Columns and XML indexes Blog bot DAX Blogs 0 28.10.2015 20:11
kurthatlevik: AX suggestion: XML Columns and XML indexes Blog bot DAX Blogs 0 28.08.2015 13:11
axsa: Sprinkling a little bit of IoT around Contoso's Dynamics business process to make it more intelligent Blog bot DAX Blogs 0 02.03.2015 18:12
Microsoft Dynamics CRM Team Blog: Microsoft Connect: One Stop Suggestion Depot Blog bot Dynamics CRM: Blogs 0 11.04.2009 00:05
Часовой пояс GMT +3, время: 04:55.
