Старый 16.08.2013, 11:47   #1
zipo is offline
zipo
AOS Cannot load assemblies - AX2012 R2
Господа подскажите что это за ошибки и как с ними бороться?
При старте АОС в Windows Application Log добавляются такие записи с типом Information:
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.MatrixPivotGrid, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Analytics, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Client.Controls, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Frameworks.ProductConfiguration, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Kernel.Client, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Workflow.Metadata.Wizard, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Workflow.Model.Design, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.StoreConnect.MessageTreeControl, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies.
Object Server 01: Could not load assembly 'RetailControls, Version=5.3.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies.
Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.StoreConnect.TransAutomClient, Version=0.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=x86' or one of its dependencies.
Could not load assembly 'EInvoiceCFDI_MX.dll.config' or one of its dependencies.
Object Server 01: Could not load assembly 'ElectronicFiscalDocument_BR.dll.config' or one of its dependencies.
ДЛЛки эти вроде как клиентские и почему их АОС вообще пытается загрузить загадка.
Ax2012 R2 update The aos cannot be reached nano3 DAX: Администрирование 7 01.03.2013 10:56
ukax: Dynamics AX2012 R2 Launches!!!! Blog bot DAX Blogs 0 04.12.2012 19:11
axinthefield: Are your AX 2012 AOS servers load balancing? Blog bot DAX Blogs 0 02.05.2012 13:11
emeadaxsupport: AX2012 and AX2009 or AX4 side by side - AOS performance counters overwritten Blog bot DAX Blogs 0 13.03.2012 18:11
axinthefield: AOS Load Balancing Blog bot DAX Blogs 0 20.01.2012 23:13
Часовой пояс GMT +3, время: 23:23.
