Старый 13.06.2017, 20:12   #1
stoneridgesoftware: Field Level Permissions in Dynamics 365 for Operations
Источник: https://stoneridgesoftware.com/field...or-operations/
The security model in Dynamics 365 for Operations has not changed much from AX 2012.  In my opinion, the changes that have been made clarify the existing AX 2012 concepts and how you use them. Field level permissions in Dynamics 365 for Operations is one of the concepts that has been made clearer. In AX 2012 field level permissions are possible — but not easy to set up. In Dynamics 365 (D365) for Operations, they are straight-forward.
How to implement field level permissions in Dynamics 365 for Operations:
1.  In Visual Studio in the Application Explorer go down to the Security node and expand Security Privileges.  Find the privilege you would like to extend, right-click and choose Create extension.  If you prefer to use a custom security privilege, right-click on your Visual Studio project and choose Add > New Item.  In the dialog that opens select Security > Security Privilege.
2.  In the designer for your security privilege right-click on the Permissions node and choose New Permission.
3.  In the property sheet for the new permission set the Name property to the name of a table containing the fields you want to secure.
4.  Once the table has been selected, the permission will display the name of that table.  Right-click on the table and choose New Field.  (You can restrict as many fields as you like on this table.)
5.  In the property sheet for the new field set the Name property to the name of the field you want to security permissions on.
6.  Set the Grant property to the level of permissions this privilege should have on that field.  The choices for the Grant property are:
a.       Unset
b.      No Access
c.       Read
d.      Update
e.       Create
f.        Correct
g.       Delete
7.  Finally, add your privilege to a security duty or directly to a security role and the role will have the permissions you have set for those fields.
Have a great and productive day!
stoneridgesoftware: How to Integrate Power BI with Dynamics 365 for Financials Blog bot DAX Blogs 0 01.04.2017 02:17
jaestevan: Dynamics 365, AppSource, PowerApps y compañía… ¿Qué esperar del futuro de los ERP en Microsoft? Blog bot DAX Blogs 0 26.07.2016 22:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
NAV Team: Upgrading from Microsoft Dynamics NAV 2009 R2 or Microsoft Dynamics NAV 2009 SP1 to Microsoft Dynamics NAV 2015 Blog bot Dynamics CRM: Blogs 0 23.02.2015 13:00
Часовой пояс GMT +3, время: 20:47.
