Старый 22.10.2017, 18:12   #1
sinedax: Empty Database in your VHD All-in-one Machine - Microsoft Dynamics 365 for Finance & Operations
Источник: http://sinedax.blogspot.com/2017/10/...ll-in-one.html
Hi All
As you know, in an Azure Sandbox Environment you can decide if create it with or without Data.
This is not possible when you download the VHD All-in-one machine.
In order to achieve this result from my understanding there are two options:
  • André post, https://kaya-consulting.com/how-to-s...your-local-vm/where you have to create before the Env in Azure with an Empty Database, Backup it and move to your VHD
  • I have Play around to the VHD Disk C and I notice a folder named “EmptyDataset” with inside a Database backup named “AxBootstrapDB_Empty.BAK”
    I have simply restore this backup file against the AX Database and set the right GUID and email id retrieved from the “old” AX Demo Data.
Till soon!
ax7, vhd
stoneridgesoftware: Microsoft Dynamics 365 – Right around the Corner Blog bot DAX Blogs 0 10.10.2016 21:13
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 13 Blog bot Dynamics CRM: Blogs 0 27.03.2013 22:12
Microsoft Dynamics CRM Team Blog: The Microsoft Dynamics CRM Swiss Army Knife Blog bot Dynamics CRM: Blogs 1 19.04.2012 08:20
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
Часовой пояс GMT +3, время: 20:06.
