Старый 01.11.2017, 16:11   #1
25,644 / 848 (80) +++++++
crmtipoftheday: Tip #1013: Include attributes that are not there
Источник: https://crmtipoftheday.com/1013/incl...are-not-there/
New Developer Guide, as it turned out, contains a lot of useful nuggets, little enhancements that make developer’s life much easier.
How many times did you need some field values for the use in javascript but didn’t really want to include the fields on the form? Something like lattitude and longitude, for example. Would it mean much to a user if I showed values -33.868820 and 151.209296? But I could definitely use those values to display a map with a pin indicating my current location.
The workaround used to be to add fields to the form but then set them to be invisible. Starting from version 9.0 you no longer need to add attribute to the form, you can instead set the attribute as a dependency for the JavaScript web resource:
  • Attribute will be available within the client API attributes collection.
  • The controls collection of the attribute will be empty.
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 16 Blog bot Dynamics CRM: Blogs 0 23.01.2014 03:15
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Часовой пояс GMT +3, время: 06:42.
