powerobjects: Custom Case Origin Icons in Dynamics 365
Источник: https://www.powerobjects.com/2017/12...-dynamics-365/
============== ![]() When viewing a list of cases, each case displays an icon in the left-hand column. Dynamics 365 already has icons in place for Phone, Email, Web, Facebook, and Twitter. The default list provided can be added to, but a default icon is added to each ( ![]() 1. Create your Icon This must be a 16×16 pixel image ideally a .png file with transparent background. Tip: Find a suitable image or icon via Google Images (or similar search engine), then convert to /png, remove the background and reduce to 16×16 using an image editor such as icofx3 or similar ensuring the reduced size icon is suitable. 2. Enter the new option into the Case Origin option set (incident_caseorigincode) ![]() It is essential to note the Value of your new option. In this example, WhatsApp has a value of 100000003. 3. Upload the image as a Web Resource into Dynamics 365. Name: the name of the Web Resource must adhere to specific rules in order for it to be recognized and applied to the new Case Origin option:
![]() Display Name: the display name can be anything. Tip: use the Display Name when uploading to list all related icons together. Keep the name consistent, for example, begin all icons for the origin options as ‘Case Origin’. Description: the description can be anything. Make it representative of the icon for future reference. ![]() Type: this must be as per the upload image file, for this example, PNG format. JPG format; GIF format; ICO format are also permitted. Language: this is optional. Upload File: select the image file to upload and, once uploaded, the ‘URL’ field will be completed, in which you will see the full pathname. The file name must be: new_incident_origincode_icon999999999.ext where 999999999 is the option value and .ext is the image file type. In the example, this will be https://mysystem.crm4.dynamics.com//...n100000003.png Once uploaded and published, the icon alongside the record for the new origin will be the new icon! ![]() Now you know how to your own Custom Case Origin Icons! For more helpful tips and tricks subscribe to our blog! Happy Dynamics 365’ing! Источник: https://www.powerobjects.com/2017/12...-dynamics-365/
