Старый 19.03.2018, 11:11   #1
alirazazaidi: Parameter _reportName cannot be null or empty. Dynamics Ax 2012 R3
Источник: https://www.tech.alirazazaidi.com/pa...cs-ax-2012-r3/
Hi, All, After Incremental CIL,  errors started to appear on controller classes. These are all those classes where report Name is mentioned in code. Error message in compilation as below.
When we compiled respected class, This error move to next controller class. After compiling number of classes. Finally We decided to compile the all classes by right click on Classes node of AOT.
Compilation of all classes in AX resolved the issue.
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: Cumulative Update 8 for Microsoft Dynamics AX 2012 R3 now available! Blog bot DAX Blogs 5 24.11.2014 17:06
DAX: Calling all developers: how to ease the learning curve of Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 27.08.2014 22:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
Часовой пояс GMT +3, время: 00:32.
