Старый 16.09.2018, 21:14   #1
alirazazaidi: Method ‘send’ in COM object of class ‘CDO.Message’ returned error and lesson learned Dynamics Ax 2012 R3.
Источник: https://www.tech.alirazazaidi.com/me...cs-ax-2012-r3/
Very interestingscenario we faced in one customization. Requirement was very simple anddeveloper used very code to send Email.
Usually testing willbe done on dev box which has both AOS and client installed on same machine. Noerror occurred and code shipped to production. But when we deploy the code onproduction server and test the email sent functionality we got following error.
Method ‘send’ in COM object of class ‘CDO.Message’ returned error code 0x8004020F () which means: .
After trouble shootwe found that when we run the AX client from another machine pointing to AOSthis error occurred. There is some network security issue which did not accessrights to SMTP server while running code from Client.
So what is solution.Then we explore how Ax send email. What is out of the box solution.
We found that in outof the box functionality, AX did not send email immediately,  Instead, they stored required information insome tables and then Batch sent emails on Server.
So We changed ourdesign and new code just inject information into out of the box tables andemails goes with out of box batch job. Only attachment part was little bittricky.
Recommendation andlesson learned that, instead calling Smtp server directly on code, we have touse out of the box functionality and just integrate it.
Email sending to customer/vendor using built-in functionality in ax 2012http://www.schweda.net/blog_ax.php?b...;vtid=YXgzMA==
Старый 17.09.2018, 11:49   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
There is some network security issue which did not access rights to SMTP server while running code from Client.
Весьма вероятно, люди не в курсе, что настраивать пароль для SMTP-сервера надо на каждом АОСе, через который предполагается отправлять почту
О, сколько нам открытий чудных...
Часовой пояс GMT +3, время: 04:01.
