Старый 17.09.2018, 20:13   #1
a33ik: Function SysOperationDataContractInfo::newParameterInfo has been incorrectly called
Источник: http://daxonline.org/1623-function-s...ly-called.html
Problem
DictMethod, when it is running without debugger, does not correctly fetches metadata of inherited methods on a child class.
Following code:
static void VKDictMethodTest(Args _args){ DictMethod dictMethod; str parmName; int parmIndex = 1; dictMethod = new dictMethod(UtilElementType::ClassInstanceMethod, classNum(AssetProposalAcquisition), 'buildRange'); parmName = dictMethod.parameterName(parmIndex); if (parmName) { info(strFmt("ParmName: %1", parmName)); } else { throw error("incorrect"); }}
As can be seen from hierarchy browser the method buildRange is available at AssetProposal class.
Depending on the debug mode option, the execution of code above will give different results.
Debug mode: No
It does not able to fetch first parameter name.
Debug mode: When breakpoint
ParmName: _items
Impact
SysOperation framework uses DictMethod to prepare parameters for method execution
\Classes\SysOperationServiceController\getDataContractInfoObjectsInternal
<div>protected Map getDataContractInfoObjectsInternal(){ SysDictClass dataContractClass; DictMethod dictMethod; int parameterCount; int i; Object dataContractObject; SysOperationDataContractInfo contractInfo; Map dataContractInfoObjects; dataContractInfoObjects = new Map(Types::String, Types::Class); dictMethod = this.getServiceOperation(); if (dictMethod) { parameterCount = dictMethod.parameterCnt(); for (i = 1; i
NAV Team: Extensibility for the Microsoft Dynamics NAV Tablet Client Blog bot Dynamics CRM: Blogs 0 09.10.2014 15:00
a33ik: CRM 4.0 - function which returns current user lookup Blog bot Dynamics CRM: Blogs 0 25.07.2011 03:40
CRM DE LA CREME! Some useful CRMform jscripts Blog bot Dynamics CRM: Blogs 0 02.09.2009 10:05
Часовой пояс GMT +3, время: 02:16.
