Старый 21.11.2018, 14:11   #1
crmtipoftheday: Tip #1196: Flow does not contain data
Источник: https://crmtipoftheday.com/1196/flow...-contain-data/
Being a mature product, Dynamics 365 rarely lends itself to short tips these days. Microsoft Flow, new kid on the block, on the other hand, is ripe for short bursts of wisdom. Today’s one is from Rob Dawson (and you can send your nugget to jar@crmtipoftheday.com too!)
With the drive toward use of Flow instead of background workflows, some condition operators are not the same. Like this easy but frequently used one.
It’s always good practice to check if a value exists before overwriting it in a workflow. Dynamics 365 CE or CDS Workflow condition is Does Not Contain Data. This is how to do it in Flow. Select the field from the Dynamic content then null function from the Expression builder.
(Facebook and Twitter cover photo by Jonas Jacobsson on Unsplash)
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
crmtipoftheday: Tip #1041: Make Dynamics 365 data import less rigid Blog bot Dynamics CRM: Blogs 0 11.12.2017 03:41
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
Часовой пояс GMT +3, время: 23:05.
