Старый 05.02.2019, 04:20   #1
axtoday: Chain of Command - avoiding the next call
Источник: http://axtoday.blogspot.com/2019/02/...next-call.html
This is possibly something that needs to be used very sparingly if at all, but apparently there is a way (up until the latest version - v8.1) to avoid calling the next() call when using chain of command.
The key is to use double nested conditions:
//this will not work "call to 'next' should be done only once and unconditionally"
protected voidchooseLinesPackingSlip(boolean _append)
If (true)
this.somethingElse(_append);
return;
nextchooseLinesPackingSlip(_append);
//this will work
protected void chooseLinesPackingSlip(boolean _append)
If (true)
if (true)
return;
next chooseLinesPackingSlip(_append);
sertandev: AX7 (D365) Chain of command with example Blog bot DAX Blogs 0 20.03.2018 13:11
sertandev: AX7 (D365) Chain of command with example Blog bot DAX Blogs 1 15.11.2017 19:38
dynamicsnavax: Chain of Command–next() gotcha Blog bot DAX Blogs 0 27.10.2017 10:11
emeadaxsupport: Enabling the new Call Center Channel User Functionality in AX 2012 R3 Blog bot DAX Blogs 0 02.09.2014 18:11
Gareth Tucker: Call Centre Optimised CRM–An Example Solution Blog bot Dynamics CRM: Blogs 0 07.09.2011 17:11
Часовой пояс GMT +3, время: 15:46.
