saurav-nav: MSDYN365BC - Futuristic CAL Development - Customize Base Code 3.
Источник: https://saurav-nav.blogspot.com/2019...opment_25.html
============== Hi Readers,As discussed in the Last article, in this post we will continue with our Customer Requirements. If you are new to this series then Please Refer Table of Index. In this article, we will discuss adding custom code in base objects and what is the Futuristic way of adding code. In your customer are Pre-2018 then you can use Hooks for those instances. (Refer Old articles to check how to use Hooks). Источник: https://saurav-nav.blogspot.com/2019...opment_25.html
