Старый 04.03.2019, 17:11   #1
25,644 / 848 (80) +++++++
a33ik: Adjust tax value using X++ code
Источник: http://daxonline.org/1641-adjust-tax...ng-x-code.html
Adjust tax value of purchase invoice. commonLine could be either MarkupTrans or VendInvoiceInfoLine.
static void VKTaxRegulation(Args _args){ PurchTotals purchTotals; TaxPurch taxPurch; VendInvoiceInfoTable vendInvoiceInfoTable; MarkupTrans commonLine; //VendInvoiceInfoLine commonLine; TaxRegulation taxRegulation; select firstOnly vendInvoiceInfoTable where vendInvoiceInfoTable.Num == "VKTest10"; purchTotals = PurchTotals::newParmTable( vendInvoiceInfoTable, PurchUpdate::All, AccountOrder::None, vendInvoiceInfoTable.ParmId, '', vendInvoiceInfoTable.Ordering); purchTotals.calc(); taxPurch = purchTotals.tax(); select commonLine where commonLine.RecId == 5637172328; taxRegulation = TaxRegulation::newTaxRegulation( taxPurch, null, commonLine.TableId, commonLine.RecId ); taxRegulation.allocateAmount(22); taxRegulation.saveTaxRegulation(); info('done');}
Adjust tax value for purchase order:static void VKTaxRegulationPO(Args _args){ PurchTable purchTable; PurchLine purchLine; TaxRegulation taxRegulation; purchTable = PurchTable::find('VK-001113'); purchLine = PurchLine::find('VK-001113'); taxRegulation = TaxRegulation::newTaxRegulation( PurchTotals::getTax(purchTable), null, tableNum(PurchLine), purchLine.RecId ); if(taxRegulation) { taxRegulation.allocateAmount(12); taxRegulation.saveTaxRegulation(); }}
In order to process VAT adjustments at line level, the country region should be added to the list of Consolidation Countries.
\Classes\SysCountryRegionCode\isLegalEntityInConsolidatedCountryRegion
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Microsoft Dynamics CRM Team Blog: Check your JavaScript code to prepare for your upgrade Blog bot Dynamics CRM: Blogs 0 24.08.2013 04:19
Часовой пояс GMT +3, время: 09:57.
