Старый 17.05.2020, 11:17   #1
cleverax: MSDyn365FO: How to use document branding with configurable business documents
Источник: https://cleverax.wordpress.com/2020/...ess-documents/
If you worked with configurable business documents, you may already know that all templates supplied by Microsoft has standard predefined image in the layout. Of course, it does not make any sense to leave it as it is, therefore you must either manually change it in all the templates or bind this image in a … Continue reading MSDyn365FO: How to use document branding with configurable business documents →
configurable business documents, d365fo
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
stoneridgesoftware: PrecisionForms for Document Management in Dynamics AX Blog bot DAX Blogs 0 14.09.2017 19:11
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
Часовой пояс GMT +3, время: 16:29.
