Старый 24.09.2020, 10:14   #1
butenko.pro: How to get type of the instance (production/sandbox/something else) using code
Источник: https://butenko.pro/2020/09/24/how-t...se-using-code/
I was working on the plugin where logic had to work differently depending on the type of the instance, i.e. if code is executed in Sandbox environment – do A, if code is executed in Production – do B. I never developed anything similar before and search engines did not bring anything valuable. After research ...
butenko.pro: JS: How to get the originating record reference in the form script of the Quick Create Form Blog bot Dynamics CRM: Blogs 0 16.09.2020 06:40
butenko.pro: How to generate Excel Template from code Blog bot Dynamics CRM: Blogs 0 19.03.2018 17:11
butenko.pro: Microsoft Dynamics 365 v9.0: How to fix connectivity issues between SSDT + Report Authoring Extension and Dynamics 365 Blog bot Dynamics CRM: Blogs 0 15.02.2018 02:15
crminthefield: CRM Online Test Instance Changes are now live (Sandbox Instances) Blog bot Dynamics CRM: Blogs 0 21.03.2014 21:14
Часовой пояс GMT +3, время: 08:05.
