Старый 09.02.2021, 05:17   #1
dynamicsnavax: Tips for getting detailed error message from Dual Write
Источник: http://dynamicsnavax.blogspot.com/20...r-message.html
In some cases Dual Write gives you some cryptic error messages. Here are a couple of tips to get or find the errors.
Tip 1.
If you get an error while mapping or trying to set up a new map. You can get a bit more info from using browser developer tools.
In Chrome, just right click and select Inspect.
Click on Network and start recording (trace).
Hopefully you get a bit more detail with the error.
Tip 2
If you are getting an integration error. There is a table that stores all the errors.
https://XXXaos.cloudax.dynamics.com/...lWriteErrorLog
For more troubleshooting tips from Microsoft. Check out their docs page.
https://docs.microsoft.com/en-us/dyn...roubleshooting
msdynamicsworld: From the Microsoft Dynamics AX/365 Finance and Operations Blogs: AX integration; Dual write; New feature; D365FO performance Blog bot DAX Blogs 1 26.01.2021 10:16
msdynamicsworld: Microsoft prepares launch of Dynamics 365 dual-write for bi-directional ERP-CRM integration Blog bot DAX Blogs 0 30.03.2020 20:12
Часовой пояс GMT +3, время: 07:35.
