Вернуться   AXForum > BI > BI Blogs
Старый 03.02.2021, 18:11   #1
alirazazaidi: How to make dashboard with Power BI and Dynamics 365 For Finance and Operations
Источник: https://www.tech.alirazazaidi.com/ho...nd-operations/
Hi everyone this little bit longer video, more then 35 minutes. Where record the complete process from Power BI to D365. Power BI is extremely easy. If you know only excel then you can easily work.
In this video you can connect with Dynamics 365 for finance and operations and make dashboard on it. I used Contoso data. If you complete watch this video you can easily understand following points.
Power BI Connections.
Download and install power BI.
How to connect with Dynamics 365 for finance and operations.
Load data,
Transform data Create calculated columns
Create measures Creates Custom tables Make Model based on tables.
Then make use different charts to make dashboards.
everythingdynamicsaxbi: How to: Configure Power BI Embedded for Dynamics 365 for Finance and Operations (One-box environment) Blog bot DAX Blogs 0 04.02.2019 01:49
powerobjects: Power BI URL Query in Dynamics 365 for Customer Engagement (CE) Blog bot Dynamics CRM: Blogs 0 26.01.2019 04:02
powerobjects: How to Integrate Power BI with Dynamics 365 for Finance and Operations Blog bot Dynamics CRM: Blogs 0 26.06.2018 01:23
stoneridgesoftware: Configuring Power BI Integration for Dynamics 365 Workspaces Blog bot DAX Blogs 1 07.03.2017 10:04
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
Часовой пояс GMT +3, время: 08:16.
