Старый 07.10.2013, 20:11   #1
25,644 / 848 (80) +++++++
axinthefield: SQL Server Trace Flag 2371 for Dynamics AX
Источник: http://blogs.msdn.com/b/axinthefield...namics-ax.aspx
In my travels around the country from one Dynamics AX customer to another the customer is usually aware of how important database Statistics are to the overall performance of Dynamics AX. The one thing I do not find though is Trace Flag 2371 enabled ...(read more)
Старый 15.03.2021, 10:50   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Блог переехал на Dynamics community
-ТСЯ или -ТЬСЯ ?
sql server
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2012 and SQL Server 2012 SP1 with Dynamics AX 2009 SP1 Blog bot DAX Blogs 3 27.05.2013 14:41
axinthefield: Dynamics AX Tracing (Part 3) Blog bot DAX Blogs 0 26.06.2011 10:11
fed: Tracing in Dynamics AX 4 and 2009 Blog bot DAX Blogs 0 10.03.2010 20:05
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Часовой пояс GMT +3, время: 15:37.
