Старый 09.06.2021, 22:12   #1
waldo: A somewhat easier way to generate a DGML Dependency Graph of your Business Central extensions
Источник: https://dynamicsuser.net/nav/b/waldo...ral-extensions
You might have read my post “Visualize app.json dependencies in VSCode (using GraphViz)” where I explained “another” way to generate a dependency graph. Another than what? Well – other than the DGML that was just announced on Microsoft’s Launch Event of Business Central 2020 Wave 2 as being “on the drawing board”.
Well – today Stefano Demiliani found out that the first bits are already on our system. He did that in his blogpost: “Dynamics 365 Business Central: creating a DGML dependency graph for your extensions“, for which I don’t really have anything to add.
Except for one little thing…
I don’t think a lot of people are that familiar with running the alc.exe .. or handling any of its parameters just from the top of their heads. So I decided to dive a bit in TypeScript again to make that part a bit easier for you.
And the “CRS: Compile DGML” command was born as part of the “waldo’s CRS AL Language Extension“:
The function will:
1) Find your working directory
2) Find the alc.exe
3) Find out the symbol path from your settings
And run the command that needs to run to generate the DGML of your current project.
This is obviously an alpha version.. and I’m pretty sure it will never become a beta as I expect Microsoft to come with their own command or settings (if not yet already).
But for now .. Enjoy
waldo: Microsoft Dynamics 365: 2020 release wave 2 plan Blog bot NAV: Blogs 0 14.07.2020 21:16
waldo: Microsoft Dynamics 365 Business Central – 2019 Spring Release Blog bot NAV: Blogs 0 02.04.2019 09:11
waldo: Developing Business Central Extensions/Apps in Team – Follow Up Blog bot NAV: Blogs 0 28.02.2019 12:11
alexef: How to add a field to Item Card in Business Central Blog bot NAV: Blogs 0 22.05.2018 20:11
waldo: Microsoft Dynamics 365 Business central – Resources Blog bot NAV: Blogs 0 02.04.2018 11:11
Часовой пояс GMT +3, время: 17:37.
