Старый 28.10.2021, 01:20   #1
Alexdmeyer: Using TPF to Protect Sensitive Data in Grid Columns for D365FO
Источник: https://alexdmeyer.com/2021/10/27/us...ns-for-d365fo/
I’ve covered the topic of the Table Permission Framework previously but wanted to give an example of how it can be used for protecting columns within grids in D365FO. Scenario There is a form within D365FO that contains a grid that has a sensitive data within a particular column that you would like to hide […]
The post Using TPF to Protect Sensitive Data in Grid Columns for D365FO appeared first on Alex Meyer.
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
littleax: Simple Rest API in D365FO, D365F, D365SCM Blog bot DAX Blogs 0 23.06.2020 14:12
patrickmouwen: 1yr with AX7 Data Management – My top 12 learnings Blog bot DAX Blogs 2 12.10.2016 15:14
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
Часовой пояс GMT +3, время: 17:10.
