Старый 09.02.2022, 08:11   #1
How to validate filename with regular expressions
Источник: http://alexvoy.blogspot.com/2022/02/...h-regular.html
I took the idea from this forum https://stackoverflow.com/questions/...-under-windows
We can use regular expressions to check if a given file name is valid.
/// Validates a filename for incorrect characters
public boolean checkFileName(Filename _fileName)
var bad = System.IO.Path::GetInvalidFileNameChars();
var esc = System.Text.RegularExpressions.Regex::Escape(new System.String(bad));
var exp = new System.Text.RegularExpressions.Regex("[" + esc + "]");
if (exp.IsMatch(_fileName))
return checkFailed(strFmt("@SYS339524")); // The specified filename is invalid.
return true;
emeadaxsupport: How to validate and investigate SAF reports for Poland using Notepad++ Blog bot DAX Blogs 0 15.08.2016 12:11
msdyncomm: How Do I: Utilize the New RenderFormat Expressions in Microsoft Dynamics NAV 2013 R2 Blog bot NAV: Blogs 0 18.04.2014 01:13
axaptapedia: Regular expressions Blog bot DAX Blogs 0 04.06.2008 02:06
Palle Agermark: Use regular expressions in the Find dialog Blog bot DAX Blogs 1 22.03.2007 21:01
Часовой пояс GMT +3, время: 00:12.
