Старый 22.02.2022, 14:11   #1
a33ik: How to store encrypted passwords in D365FO
Источник: http://daxonline.org/1745-how-to-sto...in-d365fo.html
Here is how you can store encrypted passwords in D365FO:
1. Preferably create a new table specifically for this purpose
Created a new field of type container and EDT EncryptedField called "Password"
2. Overwrite update and insert methods of the table:
public void update() { Global::handleEncryptedTablePreUpdate(this); super(); Global::handleEncryptedTablePostUpdate(this); }public void insert() { Global::handleEncryptedTablePreInsert(this); super(); Global::handleEncryptedTablePostInsert(this); }
3. Add edit method to the table
public edit Password passwordEdit(boolean _set, Password value) { System.Exception ex; Password password = ''; try { password = Global::editEncryptedField(this, value, fieldNum(VKParameters, Password), _set); } catch (ex) { boolean exceptionNested = false; while (ex != null) { exceptionNested = true; ex = ex.InnerException; } if (_set) { warning("Failed to save the password. Please try again"); } else { warning("Failed to read the password. Please clear and re-enter the password."); } } return password; }4. On the form, change property Password Style = Yes for the password controll
To un-encrypt stored password you can use same passwordEdit method:
Info(parameters.passwordEdit(false, ''));
Standard example:
  • System administration / Setup / Email / Email parameters / SMTP settings
  • SysEmailParameters form
  • SysEmailSMTPPassword table
sertandev: How to integrate with Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 21.08.2020 15:12
sertandev: How to receive D365FO push notifications using Azure Notification Hubs Blog bot DAX Blogs 0 04.07.2019 18:11
stoneridgesoftware: How to Create Secure Passwords and Use a Password Manager Blog bot DAX Blogs 0 13.01.2018 02:21
a33ik: How to import project from one model to another (D365FO) Blog bot DAX Blogs 0 26.12.2017 19:11
Часовой пояс GMT +3, время: 11:24.
