Старый 20.08.2008, 16:15   #1
Arahnid is offline
Arahnid
880 / 60 (4) ++++
Vista Home Bas and Axapta 3
Вместо слов извращение. Кодовая страница я так понимаю не работает уже в новом Win. Что делать?
SP4 стоит
Старый 20.08.2008, 16:50   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Создай файл с расширением *.reg
вставь туда
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nls\CodePage]
"1250"="c_1251.nls"
"1251"="c_1251.nls"
"1252"="c_1251.nls"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes]
"Arial CE,238"="Arial,238"
"Arial CYR,204"="Arial,204"
"Arial Greek,161"="Arial,161"
"Arial TUR,162"="Arial,162"
"Courier New CE,238"="Courier New,238"
"Courier New CYR,204"="Courier New,204"
"Courier New Greek,161"="Courier New,161"
"Courier New TUR,162"="Courier New,162"
"Helv"="MS Sans Serif"
"Helvetica"="Arial"
"Times"="Times New Roman"
"Times New Roman CE,238"="Times New Roman,238"
"Times New Roman CYR,204"="Times New Roman,204"
"Times New Roman Greek,161"="Times New Roman,161"
"Times New Roman TUR,162"="Times New Roman,162"
"Tms Rmn"="MS Serif"
"Arial Baltic,186"="Arial,186"
"Courier New Baltic,186"="Courier New,186"
"Times New Roman Baltic,186"="Times New Roman,186"
"System,0"="System,204"
"Fixedsys,0"="Fixedsys,204"
"Small Fonts,0"="Small Fonts,204"
"MS Serif,0"="MS Serif,204"
"MS Sans Serif,0"="MS Sans Serif,204"
"Courier,0"="Courier New,204"
"Arial Cyr,0"="Arial,204"
"Courier New Cyr,0"="Courier New,204"
"Times New Roman Cyr,0"="Times New Roman,204"
"Helv,0"="MS Sans Serif,204"
"Tms Rmn,0"="MS Serif,204"
"MS Shell Dlg"="MS Serif"
"Arial,0"="Arial,204"
"Courier New,0"="Courier New,204"
"Times New Roman,0"="Times New Roman,204"
"Verdana,0"="Verdana,204"
"Tahoma,0"="Tahoma,204"
"Trebuchet MS,0"="Trebuchet MS,204"
и запусти с правами админа. Должно поправить
Старый 20.08.2008, 16:53   #3
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Poleax, вы уверены, что ваш совет подходит для Vista?
Просто уточняю, возможно как раз для нее он и преднозначен
Старый 20.08.2008, 17:00   #4
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
kashperuk рецепт в принципе стандартный. Помочь должен.
Но есть уже более расжеванная тема.. прошу смотреть сюда.
Шрифты в AX 3.0
Старый 30.09.2008, 13:50   #5
tarakan is offline
tarakan
Poleax
Для VISTA не подходит, шрифт закарючками. Более того, после этих записей в реестре, в системы шрифты изменились, стал мелкий и в каких-то прогах русский не отображается!
Старый 06.04.2009, 15:30   #6
Ark is offline
Ark
Помогло просто включение по умолчанию русской раскладки клавиатуры
vista, шрифты, ax3.0
Часовой пояс GMT +3, время: 04:57.
