casperkamal: A small addition to creation of Table throug x++ code in Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!261.entry
============== A small addition to my entry on Adding a Table field through X++ code in Dynamics Ax I was actually using map's and structures to set the properties for the field type. There is also an alternative way of setting it throug the Global::setproperty method.... Global::setProperty(str properties, str propertyname, str value) I have rewritten the job based on that....... static void JobCreateTableFields(Args _args) { #AOT #TreeNodeSysNodeType //find the Table TreeNode tablenode = TreeNode::findNode(#TablesPath).AOTfindChild('LedgerTable'); TreeNode fieldNode, tn; Struct properties; Struct propertyInfo; Array propertyArray; str propertyValue; AOTTableFieldList lst; str name; Counter propertyCount; int i; Map map = new Map(Types::String, Types::String); ; //Find the tables field node lst = tablenode.AOTfindChild('fields'); //add the field lst.addString('Test'); //now find the node in the tree fieldNode = lst.AOTfindChild('Test'); //can be used when we requried to set a fewer properties fieldNode.AOTsetProperties(setProperty(fieldNode.AOTgetProperties(), 'Label', 'TestField')); //save the treenode tablenode.AOTsave(); //Let us open the table //and see if the code works :) tablenode.AOTnewWindow(); } ............................. ![]() ![]() ![]() ![]() Источник: http://casperkamal.spaces.live.com/B...CD63!261.entry
