28.10.2006, 16:40 | #1 |
Fred Shen: Undefined nodes in System Documentation after applying KR1
Источник: http://fredshen.spaces.live.com/Blog...E4E3!180.entry
============== I found that if using en-gb or de-at language after applying Kernel Roll Up 1, it will end up with Undefined nodes in System documentation. At the same time, on the property sheet of AOT, you may also find some object property displayed as *undefined* as well. What you need to do is edit your ktd file, like axsysen-gb.ktd, and locate line 1393, remove the blank line between Apostrophe(') and 1245. Everything should be back to normal. That is because ktd file contains the help text for kernel-defined method and property. The blank line makes AX unable to translate the relevant help texts. ============== Источник: http://fredshen.spaces.live.com/Blog...E4E3!180.entry |
