20.04.2007, 01:14 | #1 |
Kashperuk Ivan: Two very useful projects for DAX
Источник: http://kashperuk.blogspot.com/2007/0...s-for-dax.html
============== 1. DEV_FormControlInfo Today I downloaded a very nice project for DAX 4.0 from www.axaptapedia.com It inserts a number of lines of code into the SysSetupFormRun class, method task, providing a hotkey to access usefull information about any control on a form. The hotkey is 'Ctrl + Q'. Here is a screenshot of the result: I moved the project to DAX 3.0, because I liked it a lot. Previously I used the Tabax button, which is convenient too, but does not provide as much info as posted above. Here is the download link for the project:2. DEV_AxFind Also, my friend AndyD created a very good project for DAX 4.0 Description: After moving to DAX 4.0 a lot of users complained about the 'Ctrl + F' key combination. Now, instead of a 'Filter by Field' operation it opens a 'Global Search' window, which is uneasy to use so far. Anyway, AndyD created a small dll file that replaces the 'Ctrl + K' key combination with the 'Ctrl + F' key combination, leaving the 'Global Serach' intact, but, at the same time, providing a well known interface for DAX users. Thanks again, AndyD. :) All you have to do is download the dll file (donwload link) and add the following lines of code into the Info class: 2.1. Info\classDeclaration classDeclaration { ..... DLL dllAxFind; } 2.2. Info\startupPost void startupPost() { InteropPermission perm = new InteropPermission(InteropKind::DllInterop); ; // DEV_AxFindReplacement Replace Keys F and K when used with the Ctrl key 19.04.2007 IKASH --> perm.assert(); dllAxFind = new dll(@"D:\Install\Dynamics AX\Dynamics AX 4.0 SP1 EE\axfind.dll"); CodeAccessPermission::revertAssert(); // DEV_AxFindReplacement Replace Keys F and K when used with the Ctrl key 19.04.2007 IKASH
