Kashperuk Ivan: 3 great Tabax Plugins
Источник: http://kashperuk.blogspot.com/2007/0...x-plugins.html
============== As you might already know, starting with version 0.3 of Tabax, plug-ins are allowed to subscribe to events fired by the Tabax form. This fact couldn’t be left unnoticed. J So here are 3 plugins that you might consider useful for your DAX installations. Before installing any of the plugins, you need to install Tabax 0.3 or later and the DEV_TabaxSDK Use the following link to download the latest version of Tabax and SDK: http://axaptapedia.com/Tabax DEV_TabaxPlugin_OpenInAOT – download (homepage - http://www.axaptapedia.com/DEV_TabaxPlugin_OpenInAOT) This is a very simple plugin, based on a tool I made a while ago (you can download the original EditorScript at http://www.axaptapedia.com/Editor_scripts_OpenInAOT). This tool is available only to developers (SysDevelopment security key). Installation instructions are very simple: just import the project and refresh the AOD (this is specifically needed for the rich AX4 client) Now you can open AOT objects just by typing their name in the Tabax form edit box (prefixed with ‘go’). Here are a couple of examples:
(homepage - http://www.axaptapedia.com/DEV_Tabax...RecentProjects) This plugin, when started (which happens automatically on startup of Tabax), adds a button on the Tabax toolbar. (it resembles an ‘Undo’ button). This plugin keeps track of projects you use during the day, providing for a simple and fast way to open one of them. This tool is available to developers only. If you do not have developer rights, the button will not be added to the toolbar. Here is a list of what will happed when the button on the toolbar is pressed:
DEV_TabaxPlugin_RecentWindows - download (homepage - http://www.axaptapedia.com/DEV_Tabax..._RecentWindows) This plugin, when started (which happens automatically on startup of Tabax), adds a button on the Tabax toolbar. (it resembles a green ‘Recycle Bin’). This plugin keeps track of windows you use during the day, providing for a simple and fast way to open one of them again. This includes editor windows, AOT object windows and regular Axapta forms (this does not include forms opened from other forms). This tool is available to both dev and non-developers. If you do not have developer rights, the AOT and editor windows are not kept track of and the recent windows list is used solely for DAX forms. The nice part of this is the specific record you last used is remembered as well, so you can reopen a form and start working with the record right away. (AxPath is used for this) The functionality of the toolbar button is similar to DEV_TabaxPlugin_RecentProjects. That's it. Come back for more :) Источник: http://kashperuk.blogspot.com/2007/0...x-plugins.html
#2 |
По нижеприведенной ссылке найдете перечень существующих плагинов:
http://erpkb.com/Axapta/TabaxPlugins Также по ссылке приведен список идей и планируемых изменений. На эту страницу можно добавить свои идеи, возможно даже пожелания по поводу новых плагинов. Спасибо |
#3 |
Краткий перевод действий кнопочек
За это сообщение автора поблагодарили: belugin (7), zemlyn (2). |
