Старый 28.06.2007, 17:00   #1
25,617 / 848 (80) +++++++
dynamicsusers: SQL Server: x64 vs x86
Источник: http://dynamicsuser.net/blogs/waldo/...64-vs-x86.aspx
I recently got an interesting explanation on why x64 is more interesting when your system has more than 4 Gb of memory. The background is the size of the memory. An x86 server system can manage a maximum of 4 GB of memory. This limits the addressable memory space for Windows server 2003 systems to 4 GB. (This is true for all 32-bit operating systems). With 2 GB reserved for the operating system by default on 32-bit Windows, only 2 GB of memory remains for SQL 2000 or SQL Server 2005 x86. You can...(read more)
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
dynamicsusers: Making NAV use a certain index on SQL Server Blog bot DAX Blogs 0 21.08.2007 10:40
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
aEremenko: Диагностика проблем при установке Microsoft Dynamics Ax 4.0 на Microsoft SQL Server 2005 Blog bot DAX Blogs 0 28.10.2006 16:01
Часовой пояс GMT +3, время: 20:06.
