28.09.2007, 20:54 | #1 |
axaptapedia: WinInet class
Источник: http://www.axaptapedia.com/WinInet_class
============== Summary: Description and Extension of the WinInet class == What it can do for you == This class provides a way to interact with web-pages on the internet. To save an image from a web-link, you need to add the following method to the [[WinInet]] class: #winapi int internetSaveFile(int hdl, str _fileName) { Binary _buffer = new Binary(2048); Binary _bytesRead = new Binary(4); int cnt = 0; boolean ret; DLLFunction fileCreate; DLLFunction writeFile; DLL dll = new Dll(@"KERNEL32.DLL"); int hFile; ; if (_fileName) { fileCreate = new DLLFunction(dll, @"CreateFileA"); fileCreate.returns(ExtTypes::DWord); fileCreate.arg(ExtTypes::String, ExtTypes::DWord, ExtTypes::DWord, ExtTypes::DWord, ExtTypes::DWord, ExtTypes::DWord, ExtTypes::DWord); writeFile = new DllFunction(dll, @"WriteFile"); writeFile.arg(ExtTypes::DWord, ExtTypes::Pointer, ExtTypes::DWord, ExtTypes::Pointer, ExtTypes::DWord); writeFile.returns(ExtTypes::DWord); hFile = fileCreate.call(_fileName, #GENERIC_WRITE, 0, 0, #CREATE_ALWAYS, 0, 0); while (hFile != #INVALID_HANDLE_VALUE) { ret = _internetReadFile.call(hdl,_buffer,2000,_bytesRead); if (ret && _bytesRead.dWord(0)) { cnt += _bytesRead.dWord(0); writeFile.call(hFile, _buffer, _bytesRead.dWord(0), _bytesRead, 0); } else break; } if (hFile != #INVALID_HANDLE_VALUE) winapi::closeHandle(hFile); } return cnt; } Here is a test job showing how it works: static void internetSaveFile(Args _args) { WinInet winInet; int hdl; ; winInet = new WinInet(); hdl = winInet.internetOpenUrl("http://www.axforum.info/forums/customavatars/avatar4154_1.gif"); info (strfmt("%1 bytes saved", winInet.internetSaveFile(hdl, "c:\temp\avatar4154_1.gif"))); } [[Category:Class_development]] Источник: http://www.axaptapedia.com/WinInet_class
