04.04.2008, 10:10 | #1 |
Microsoft Dynamics Mobile version 1.1 has been released!!
Microsoft Dynamics™ Mobile, version 1.1 has been released and is available in PartnerSource.
With the new release of Microsoft Dynamics™ Mobile, Microsoft Dynamics we now have the opportunity to use the Mobile Development Tools to build end-to-end solutions for Microsoft Dynamics, create vertical applications quickly. It is based on several high level development concepts like Tasklets, Orchestrations and Wizards, therefore it reduces the application development time for mobile implementations (compared with a regular .NET Compact Framework mobile development) Dynamics Mobile 1.1 supports Microsoft Dynamic NAV 4.0 SP3 and the newly released Microsoft Dynamics NAV 5.0 SP1. It also supports Microsoft Dynamics AX 4.0 SP2. The release also contains 'Mobile Sales', which is the first mobile application for NAV and AX from Microsoft Dynamics Mobile. Mobile Sales is RoleTailored and task-oriented and an ideal solution for field sales representatives and other mobile employees who need to work in remote locations. The field sales representatives can plan visits, review relevant sales information, and create orders. Finally, Mobile Sales tasklets are incorporated into the Mobile Framework which will enable our partners to utilize the Framework to its full extension. Microsoft Dynamics Mobile is localized for Microsoft Dynamics NAV in 42 countries and AX in 30 countries. You can read much more about our products on Partnersource: https://mbs.microsoft.com/partnersource/products/mobile We have also created a Team Blog on MSDN http://blogs.msdn.com/dynamicsmobile, where we have started blogging about releases and other aspects of the development process. You can download the product from Partnersource (if you are a Dynamics partner): https://mbs.microsoft.com/partnersou...obileVersion11 Источник... http://blogs.msdn.com/cesardelatorre...-released.aspx |
04.04.2008, 11:00 | #2 |
Гость
я правильно понимаю, что это новая инкарнация Энтерпрайз-портала? Или отдельное приложение, не на браузере?
04.04.2008, 11:39 | #3 |
Не. ЕР тут совсем не причем. Это отдельный продукт, для мобильных устройств.
04.04.2008, 11:45 | #4 |
Гость
читанул английский блог, вайтпепер не скачалась. Так что тока картинка в помощь
04.04.2008, 13:22 | #5 |
Я посмотривал на предыдущую версию: реализовано на .NET compact framework, есть некий SDK чтобы дорабатывать, работает, вроде, через синхронизацию
04.04.2008, 13:48 | #6 |
Гость
меня больше стрелочки между базами интересуют. Особенно между мобиле-сервером и мобиле-клиентом. Они однонаправленные и независимые от приложение соответствующео тира. ДА вообще ни от чего независимые...
