Старый 15.05.2008, 02:27   #1
Language in user options
Источник: http://alexvoy.blogspot.com/2008/05/...r-options.html
Accidentally changed Language in User options can cause an issue with logging in to the configuration if you have not the appropriate licence for the language. In this case you might see something alike the following.
oror even
The simplest way to fix it is to change the language in User options but if you have no administrator rights or the administrator is yourself... In this case you should use Microsoft Dynamics AX Configuration Utility
Set Configuration command to run at kernel startup parameter to the value, i.g.,
-language=en-us
or another correctly licenced language.
It will override the value chosen in the user option and the configuration then works.
Now, you are allowed to say to the system - Speak My Language!
Dynamics AX: Microsoft Dynamics AX 2009 - User Experience Guidelines Blog bot DAX Blogs 0 11.07.2008 20:05
Channel9: Microsoft Dynamics CRM 4.0 Multi-Language User Interface (MUI) Blog bot DAX Blogs 0 29.12.2007 14:11
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Dynamics AX: Offbeat DLR. Dynamic Language Runtime! Blog bot DAX Blogs 1 03.05.2007 10:46
axaptafreak: Send message to online user in Dynamics AX 4.0 (quick & dirty) Blog bot DAX Blogs 0 12.04.2007 16:10
Часовой пояс GMT +3, время: 11:37.
