16.06.2008, 15:27 | #1 |
Вышел Microsoft Dynamics AX 4.0 Service Pack 2 Feature Pack 1 for Eastern Europe
Changes specific to the Russian functionality
Bug ID Knowledge Base ID* Description 26690 940701 Different sales tax amounts in a AR Free text invoice: in Totals inquiry and in a Sales tax form 27299 941759 Adding two lines in the Russian country-specific invoice format according to a local Russian legislative typical inter-industry reporting form 'TOPГ-12' 27636 942475 The system calculates incorrectly the amount in the line of FA Journal for "putting into operations" transaction for models of the account which currency is distinct from base currency. 27969 942431 Using the sales order function ’Update remaining delivery’ ends up with stack trace error 27971 942434 Stack trace error when printing Reimbursement slip/Receipt order from a Packing slip journal 28581 943098 RU- AC& AP\ Contracts\ Payment schedule is not filled in 28812 943572 Purchase book lines does not show adjusted tax amount 30144 944512 Stack trace error occurs when user is going to print Invoice For Payment from AC \ Stack trace error occurs when user is going to print Packing slip with Reimbursement order from AP 30722 945157 Dimensions in the transaction for write off cost item to FA (Db08 Cr 10) is picked up from fin dimensions from FA Posting model 30920 945237 Inventory Error message occurs when Transfer or Requirement slip is printing in case of Officials was tried to change by user 30926 945566 An error message "A section in the report is higher than the actual page size allows" in reports "Customer base data", "Vendor base data" 33240 947842 An error message “Voucher … is already used as of date …” arises when transforming a customer payment to prepayment 33963 948827 Half year straight line life remaining depreciations are not correct in Eastern Europe GLS 34734 950197 Error "Voucher XXX is already used as of date YYY" when two vendor transactions are settled together 34971 949836 RTax25Registers | Non warehoused goods register | Register calculation results do not include some transactions 36529 951572 Act of Adjustment reports shows incorrect zero debit sum in some scenario 37011 951525 Digits' delimiter in the update "Electronic reporting in txt format" 38176 953757 Company address in the Acceptance report (FA-1) if a company Address type is International |
16.06.2008, 16:27 | #2 |
\Classes\ReleaseUpdateDB401_Cust\updateFacture_RU
X++: trans.LineAmountMST = round(custInvoiceTrans.LineAmountMST * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff); trans.TaxAmountMST = round(custInvoiceTrans.TaxAmountMST * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff); trans.VATAmountMST = round(custInvoiceTrans.VATAmountMST_RU * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff); trans.ExciseAmountMST = round(custInvoiceTrans.ExciseAmountMST_RU * (trans.LineAmount / custInvoiceTrans.LineAmount), roundOff); И еще лезут в голову всякие нехорошие слова при сравнении по слоям \Data Dictionary\Base Enums\RTax25TaxModule (имеется слой с российскими зарплатой и кадрами) Зато сделали импорт курсов валют с сайта ЦБ
-ТСЯ или -ТЬСЯ ? |
17.06.2008, 20:51 | #3 |
Сообщение от Vadik
Того, что существуют строки накладной с нулевой суммой, явно никто не ожидал ... А никому не приходится хранимые процедуры в MS SQL создавать при апгрейде, которые толи не создались, толи куда-то делись, но на их отсутствие пакетный сервер ругается? Или это только я такой несчастливый? Документацию чтоли почитать ...
С уважением, glibs® |
16.06.2008, 16:58 | #4 |
Консультант
Обновленный меточный файл с полностью русскими метками есть там?
16.06.2008, 17:43 | #5 |
33240
947842 An error message “Voucher … is already used as of date …” arises when transforming a customer payment to prepayment |
16.06.2008, 18:29 | #6 |
Есть там меточный файл, только вот совсем непонятно все или не все там переведено. Вроде как заявляется (что в принципе корретно) что исправляется то, что было зарегистировано ранее как непереведенное или неправильно переведенное, то есть то что не заявлено непереведено
16.06.2008, 17:42 | #7 |
Много сделано по сторнированию операций, в том числе по складскому модулю. Надо изучать
Ivanhoe as is.. |
24.06.2008, 12:06 | #8 |
Можно скачать здесь:
https://mbs.microsoft.com/partnersou...E_Download.htm |
12.07.2008, 11:17 | #9 |
Чего-то то ли я торможу - то ли не вышел los(lop)-слой с российскими зарплатами и кадрами, поднятый на этот GLP?
Ибо ощущение после "вливания" этого FP - (26 ошибок компиляции) говорят о том, что должны были поднимать... Нет?
15.07.2008, 11:44 | #10 |
Та же фигня. Правда, не 26, а 24 ошибки. Преимущественно в объектах с префикcами RTax и RAsset. Версия приложения 4.0.2501.347.
15.07.2008, 09:51 | #11 |
У нас стоит FP1 и общий, и FP1 RHRM - ошибок нет.
Ivanhoe as is.. |
15.07.2008, 10:17 | #12 |
Не... не втыкаю. Вот гляжу в партнерсорс...
Вижу: (Support-Service Packs) Ссылка на SP2FP1 - дата последнего изменения страницы 11.06.2008. Качаю - смотрю - GLP-слой. Дата его последнего изменения - 09.06.2008 Теперь рыщу в поисках HRM & Payroll для России. Вроде нахожу: (Support-Product Releases) Ссылка на RHRM. Здесь дата последнего изменения страницы - 13.02.2008. Ладно - смотрю - на странице 3 ссылки - первая для 4.0SP1, вторая для 4.0SP2, третья просто сама по себе - ссылка на FP1 RHRM. Написано: Цитата:
Feature Pack 1 for the Russian HRM and Payroll modules - Contains regulatory updats for Russian HRM and Payroll modules for Microsoft Dynamics AX 4.0 SP2 with Eastern Europe GLS. All functionality is in the LOS layer.
Ладно - качаю FP1 RHRM - вынимаю LOS-слой. Вижу у него дата последнего изменения - 30.01.2008. Наложение слоя - ессно ведет к куче ошибок. Может кто знает другую ссылку и я неверно нашел RHRM?
Возможно сделать все. Вопрос времени Последний раз редактировалось sukhanchik; 15.07.2008 в 10:20. |
15.07.2008, 12:41 | #13 |
Беру свои слова обратно - при компиляции ошибки появились (проверил на RTax*).
Ждем нового релиза RHRM как после выхода DAX SP2? ЗЫ: у меня приложение 4.0.2501.122, ставилось: SP2 EE, RHRM для SP2, FP1 RHRM, FP1 EE. Чего-то не хватает или порядок установки другой?
Ivanhoe as is.. Последний раз редактировалось Ivanhoe; 15.07.2008 в 12:47. |
15.07.2008, 14:10 | #14 |
Порядок установки не помню, т.к. накатывал FP1 на давно стоявшее тестовое приложение. Вроде такой, но не помню, устанавливал ли я FP1 RHRM. Есть какой-то способ проверить, что он установлен?
Что касается версии приложения, то она определяется методом \Classes\ApplicationVersion\applBuildNo. У меня этот метод на слое glp, т.е., по-видимому, этот билд определяет SP2 FP1 EE. Проверьте, на каком он слое у вас. Предполагаю, что на los/lop и там как раз указана версия 4.0.2501.122. Скорее всего, это версия FP1 RHRM. |
15.07.2008, 14:19 | #15 |
Так и есть - метод на Los-слое.
Ну проверить FP1 RHRM можно, например по Штатному расписанию - если в Расчеты с персоналом / Кадровый учет / Состав / только одна форма "Штатное расписание" и нет "Хронологии расписания", то он стоит.
Ivanhoe as is.. |
15.07.2008, 14:38 | #16 |
Судя по тому, что у меня и хронология и само штатное, FP1 RHRM у меня не установлен. Щас попробую накатить его, но вряд ли результат будет положительный...
