08.08.2008, 19:06 | #1 |
dax-lessons: Generate XML Documentation Files for a project - DAX 2009
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!172.entry
============== To generate XML documentation files for a project
To generate XML documentation files for the entire application Create a folder in which you will create the XML documentation files. This procedure will reference a folder that has the path, C:\XMLDoc. Note: For security purposes, you may not be able to create XML documentation files directly on the root of a drive. At the command prompt, execute the following command to create a documentation file for the entire application: Ax32.exe -startupcmd=xmldocumentation_C:\XMLDoc\documentation.xml At the command prompt, execute the following command to create a reflection file for the entire application: Ax32.exe -startupcmd=xmlreflection_C:\XMLDoc\reflection.xml Note :When you use these commands, Microsoft Dynamics AX will automatically start and create the XML files. Microsoft Dynamics AX will automatically close when it finishes. Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!172.entry
