28.08.2008, 15:05 | #1 |
msdynamicsax: selecting data from multiple companyaccounts
Источник: http://msdynamicsax.wordpress.com/20...mpanyaccounts/
============== Some of you might have heard about the new reserved word in x++ called crossCompany. It enables you to select data across multiple companies in Ax without the use of changecompany (which I hated) Anyway, this is an example of how it works: static void getTotalLineAmount(Args _args) { SalesLine salesLine; container companies = ['dmo', 'dm2', 'dm3']; // specify the companyaccounts to select from ; select crossCompany : companies sum(LineAmount) from salesLine; info (num2str(salesLine.LineAmount,0,2,1,2)); } Источник: http://msdynamicsax.wordpress.com/20...mpanyaccounts/
